Alan_Scott
- Nov 25, 2011
- 69
94' YJ 4.0 5-speed, all original, new O2 sensor last July
It's been running fine, then I shut it off uptown and now it won't start but still turns over just fine. The only thing I've tried so far was to check the schrader valve on the fuel rail (it dribbled a bit) and then tried to start it on ether.
All of the gauges, tach and speedometer no longer function (while being towed with the key on, I tried letting the clutch out in 4th) but the dash lights are still working. The check engine light and buzzer are also dead right now.
I'm thinking that I've either lost power to the ECM or had a ECM failure. Anyone else had this type of glitch before?
