crazy charlie
- May 22, 2003
- 5,352
I have always lubed the chute and auger chamber with WD40 or similar before operating to keep the snow and ice from building up and thwarting performance.I have found and perfected the lube process by spraying cooking spray like Pam instead of spray lube.Make sure you are spraying it on a cold and dry chute.The cold surfaces will allow the cooking spray to build up and remain in place the entire time you are snow blowing.This made a HUGE difference on my snowblower.Hope this helps someone and post back if it does.Charlie
