MTboatguy
- Jul 8, 2010
- 8,988
Hey guys, I have a bit of a pickle I am trying to solve, on the way home yesterday my wife hit a pot hole on our long gravel road and busted a coil spring on the front right hand side of her subaru legacy outback which ended up shredding a tire. She changed the tire without realizing the spring had broke, drove another 3/4 mile, shredded the spare, so I go down, jack it up to put another tire on it and notice the broken coil spring which no matter how I manipulate will still rub the inside of the tire, causing heat which causes the tire to go bad.
If I could get that spring out without taking the front end apart, I could nurse it home, so I am wondering, if I can use a set of 42 inch bolt cutters to clip that spring and pull out the pieces, the spring is no longer under load, but it is still around the strut, but loose. The spring itself is about 3/8 to 5/16 inch in diameter, so I was thinking that a large set of bolt cutters would go through it?
Anybody tried this before?
Let me know your ideas, I don't have a cutting torch or electrical where the car is sitting.
Thanks.
Thanks.
