Was hoping to get the communities input on an idea I have. I am currently restoring a boat and want a wakeboarding pylon. I was thinking of running three 2X6s between the stringers with a hole drilled through the first two and the floor for the post. They would be glassed inside and out for moisture protection and when not in use the hole would be covered by a deck plate. I would run cables to support the top of the post as well but not sure how I would configure them yet. Just curious if the post base set up is a good way to go or not?
