Shell "Darina Grease" for bearings?
mars bar
A good friend of mine gave me a tube of Shell Darina grease. This grease is black in colour /color. I did some research on this grease an it's primarily used on heavy construction equipment. It apparently holds up to temp up to 350 degrees, not affected by water. Seems it should be better than regular bearing grease. Any ideas. thanks
Re: Shell "Darina Grease" for bearings?
Ayuh,.... Go ahead 'n use it, I can't feature it'd hurt anything,...
mars bar
Thanks Bond_o I just figured it be better, If it stands up to heavy equipment use it's gotta be good.
mars bar
Ayuh brother Ayuh calm seas to you.
