Re: What size trailer do I need????
OK then, I understand that you understand the GVW thing. So lets go with the boat length thing, first there is tongue weight, "how much weight can you put on the hitch", the further your boat sits ahead the more weight you have on the ball.
some one mentioned the 10% rule for tongue weight
I believe you are only allowed to have 1 yard of boat/material hang past your tail lights legally (check state DMV) you may have to add lights further out.
and were I live you cannot legally change the GVW of your trailer as it was designed for the max weight stated on the build tag.
"can you haul the boat on the trailer" I would say yes as long as you adjust the boat for the tongue weight and you make sure people can see your lights.
You did not mention the width of the beam, when you get over 8.6 feet you "could" be looking at an overwidth permit, and you will require red flags on both sides at the widest point for day travel and marker lights in the same place for night travel, check the DMV
I hope this helped alittle
rob
