Stinnett21
- Jun 24, 2012
- 454
Seeking opinions on how many times on average a hub can withstand a Buddy Bearing removal and install before you start to loose the buddy bearing
Wow that's not been my experience. I currently have 2003 UFP hub/rotors. Recently converting from oil to grease. This make the 3rd time for removal/insert. I use the standard method of removal, hit softly as possible with a dead blow and 180 degrees. Seems like now the BBs are going half the way in before any significant contact is made. Very nervous about loosing them. Isn't it true that every time that you remove them it bell shapes the hub somewhat?
assuming you dont damage the hub or bearing buddy, and you have a good quality hub (not the chinesium imports), a few hundred times
