I will go into more depth, with boats and tongue weight. As I have said in many earlier posts 10-15% tongue weight is what I recommend. If the TV a person in using is limited to 10% tongue weight, of what a person is pulling, they are probably pushing the limits of the TV much more so than is wise. Equipment trailers are easier to set up because the load can be secured and you usually know how it is loaded. Example, I will put a tractor on with the most weight forward. Usually these trailers will have pintle hitches. If I turned the tractor around the other direction, to load it, I may not have enough tongue weight to be safe.
Boats create an issue where there can be water in them that you aren't aware of. That water, as you accelerate, or if the tongue is slightly upward, can end up in the stern and significantly reduce the tongue weight.
Too little tongue weight can rip the trailer right off the TV. Excessive tongue weight, within obvious reasonable limits of the TV, won't cause instability, like little of no tongue weight will do.
