Hi all,
I went to change wheel bearings today, something I haven't done before but which seems pretty straightforward on youtube. Per spindle measurements, I have a tapered 1-1/16" x 1-3/8" setup. The races I ordered appear to be the same diameter as those I took out.
I cleaned everything up and went to press in the inner race, but it's significantly smaller than the wheel hub, unlike all the videos I saw where it needs to be pressed in all the way from the edge of the hub. There's also a lip, I think between where the race and seal would sit.
Is this a different kind of hub that requires a spacer between the hub and race, or did the hub just get messed up before I realized the bearing needed to be changed? I should mention that I changed the bearing because I saw the hub smoking in the rear view while pulling the trailer, and when I pulled the hub off the spindle, the inner race was sitting loose.
Thanks,
Matt
Thanks,
Matt
