Hey gang. First post here! I just bought my first boat, a 1999 Cobalt 252, and I'm learning how trailers work (and don't work). The trailer that came with it is a 2005 Sport Boat Trailers Cobalt 252 S25T5, and the tongue has an Atwood coupler -- see attached photo.
I'm having a problem with the coupler's brakes repeatedly engaging when I'm backing it up a slight slope into its parking slot. The process is as follows:
I ended up having to force the little slider to stay in its damned notch with a bungee cord, to be able to park my boat.
Seeing as how my designated boat parking space is on a slope, I'm going to have this battle each and every time I try to park my boat. I sure would appreciate some suggestions on how to fix this, including upgrading the coupler if necessary.
- Start to back up the slope,
- "click!" and the trailer brakes lock up.
- Curse profusely. Pull forward slightly to disengage trailer brakes.
- On the coupler, slide the little slider along a curve from "TOWING" to "BACK-UP POSITION," and then drop it into the little notch at the very bottom,
- (Sometimes, the slider will move down but it won't drop into the notch -- so I have to wedge a piece of wood under the trailer tire and drive forward over the wood to "fix" it so it drops into the notch)
- Get back in the truck. Back up the hill about 2 feet.
- Click! and the trailer brakes lock up.
- Go back to step 3
