Ahoy mates, I'm new to the forum, but been enjoying boating and life on the water for years. I've got a 2003 Sea Ray 182 bowrider for skiing, a canoe and kayak for chilling. I recently bought a little 14 foot Monark M-1 sailboat at a price that was almost a giveaway. It's in decent sailing condition, but one thing is worrying. The boat's got two retractable centerboards that aren't removable (or if they are I don't know how to do it!). They are positioned up under the hull, and ropes come up through the hull so that you can pull one end of the rope and a board will lower, pull the other end and the board raises. These ropes are severely frayed, and I'm fearful that they will break soon and I'll be stuck with a centerboard that I can't raise. Anyone have experience with replacing these ropes or removing these centerboards?
Announcement
Collapse
No announcement yet.
Need help with replacing the ropes on Monark M-1 centerboards
Collapse
X
Spend some time figuring out how to remove the CB's. There is probably a bolt that the boards pivot on. Once you are able to lower the centerboards from the hull you can dress them up with new lines, feed the lines up through their respective holes in the CB trunk and then reinstall the CB's.Best regards, Ted. . . . Cape Cod, MA
Current Boats: Formula 330 Sun Sport, O'Day Mariner Sail #3224, Sunfish
Past Boats: Catalina 22 Sail #10531, Formula 242 Sun Sport
Twin Mercruiser 7.4 LX MPI (0F802036, 039), Bravo 3's (0F806198, 199), Mercury 7.5 HP (1969), Johnson 4.5 HP (1980)
My Boating Web Pages: http://www.tpenfield.com
I've raised the boat off the trailer to give it enough height to lower the centerboards all the way down.... there's a groove along which the pivot should be able to slide while removing/lowering the centerboard. I was thinking that there was a particular angle that you position the centerboard that lines up the pivot with the groove, making it easy to slide out. But no luck so far... can't seem to find the magic position to slide it out. And there's no bolts or hardware to remove in order to take out the boards, either. Anyone else with suggestions.
Comment
Neither here nor there, but I think you've got a Monark 14. I think* (* note the magic word) the M-1 was a daggerboard boat.
I haven't been able to see something that shows the boards from the cockpit side, but on our boats (Oday and Capri) there was a metal bracket inside the cockpit that was the pivot point for the centerboard. The bracket didn't necessarily protrude up from the sole, but you may have had to get to it from the hatch under the mast.
I'm assuming your centerboards are on either side of the cockpit under those lockers where you sit. Can you see the assembly when you open those up?
Comment
Received some feedback from another forum yesterday.... seems the pivots are spring loaded (like the bar that holds toilet paper). Trick is to insert a screwdriver and push the pivot end inward, then hold it in place while doing the same to the opposite pivot end. We'll give it a try!
- 1 like
Comment
Post some pictures when you can. It would be interesting to see the details of the keel/centerboard pin and the lines.Best regards, Ted. . . . Cape Cod, MA
Comment
iboats Boating Forum Directory
Over 100,000 Questions & Answers
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Activities and Destinations
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats (250+ Manufacturers)
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Comment
