Re: XLT 1200 power loss/rpm loss after take off
Does it still have the catalytic converter? If so, I'd take the exhaust apart and see if it has broken loose.............very common problem on this model. It will make the ski run like crap. Even if the cat/con is intact, I'd consider removing it and installing a "D" plate. The cat/con tends to fail at the 10 year point on these skis.
Other common problem would be the power valves not working or possibly have come loose and fallen. Have you installed wave eater clips for the power valves? I'd check the servo motor for the PVs and the PVs themselves. If you haven't installed the clips, you might want to consider installing them. Most likely one of these 2 problems.
