Hello all. You will definately be able to tell I'm an in-experienced boater by the question I ask so please just guide me in the right direction if possible.
I have a 97 Yamaha Wave Venture 1100 that ran absolutely perfect for hours on the water about 2 weeks ago. The vent to allow air into the fuel tank is not working correctly so we thought we had an issue. I pulled it out and took it home and diagnosed this issue as vapor lock. No biggie. In the mean time I can just loosen the fuel cap to let air in until I can get another vent.
So I took the boat out again this memorial day weekend. The battery was completely dead so I jump started the boat. The boat was out of the water and I hurried up and put the boat in the water. The time from starting (no reving whatsoever) to the time in the water was approximately 2-3 min. I idled the ski out past the no wake and opened it up. It ran fine. Then I hit a wave and it died. Battery was completely shot as it would not turn over. I towed it in, ran and got a new battery and it started just fine. So I took the boat back out and it hesitated to run. Acted as though it wasnt getting fuel so I had to "pump" the throttle and it would pick back up. While doing this it would eventually die after 1-2 min of riding. Then the boat would not turn over. I would just head a thud as if the starter was engaging, but not turning the motor over. If I let the boat sit and not try to start it for 1-2 min, then it would turn over and start. Almost like it was getting too hot. I'm not really sure what to do at this point. Anyone have any experience like this before?
Thanks.
Thanks.
