Ok so here is the abbreviated story. Today I started it briefly (3 sec) in the drive just to make sure it fired, hauled it to the lake backed it in the water to water test it for reliability. It ran for about 5 min but it was smoking badly, I noticed the bilge was not working so I stopped it, brought it home and fixed the bilge pump. Now it won't start and oil is leaking from the bottom around the water intake. I have changed the plugs and charged battery and checked the compression and checked spark for all 3 plugs, while doing this I noticed that the oil injection rod that is connected to throttle was very loose (Unsure how to set it correctly). I need help on how to check stator, trigger as well as the adjustment for the oil injector rod. As a side note the gas is about a year old so I put in some octane booster and seafoam. Thanks in advance.
Scott
615-336-0664
Scott
615-336-0664
