zerobalance
- Sep 17, 2011
- 12
im having charging problems, and the ski wont get up and go. in the yard it revvs fine, in the water its dying, but will idle fine. i changed the hoses, and like 3 starters. voltage regulator, elecrtonic module. battery wont keep a charge overnite. starter solonoid is now clicking . batt is charged with 12 .35 volts. if i remove the red batt wire when its running it will die. there is 6 ohms on the rear solonoid. ... how can i test the voltage regulator? how can i test the magnito?
