Welcome Guest - Sign Up today
No announcement yet.
Hello,We have a 2009 seadoo jet ski.Our problem is we have a continuous beep.We just
  • Hello,We have a 2009 seadoo jet ski.Our problem is we have a continuous beep.We just
    put in a brand new battery today.We took it out and it was running fine.While on the water the beeping started and never shut off.We took it to the bank.We shut it off.When we went to start it to load it there was nothing.No power at all.Can you tell me what it might be? We are at our wits end and cannot figure out whats causing it.Any suggestions would be appreciated. Thanks
    Re: Hello,We have a 2009 seadoo jet ski.Our problem is we have a continuous beep.We j
    Try this:
    http://www.sea-doo.net/Specification...PROCEDURES.pdf
    One long continuous beep means an overheat issue. What did the LCD display tell you? If you put the DESS key back on to load and you don't get any thing, you either have a bad battery connection or a bad key connection. Most likely, there is salt or water in the key. Clean it and reattach. You should get 2 short beeps if all is well.
    2001 Carver Voyager 374 'Stick's Competition'
    Something tells me I should be on the water....
    If I answer your upholstery questions, it's only because I've been doing it 20+ years...
