Re: 2005 Seadoo RXP One long beep wont start
Here are what the codes are:
Monitoring Beeper Coded Signals
NUMBER OF BEEPS POSSIBLE CAUSE REMEDY
2 short (while installing safety
lanyard on DESS post).
? Everything is correct with the
safety lanyard (good contact
and right lanyard cap).
? Engine can be started
normally.
1 long (while installing safety
lanyard on DESS post or when
pressing start/stop button in
some cases).
? Bad connection between
safety lanyard cap and DESS
post.
? Remove and reinstall the
safety lanyard on the DESS
post. Two short beeps
should be heard which
indicates the system is ready
again to allow engine
starting.
? Wrong safety lanyard. ? Use the safety lanyard that
has been programmed for
the boat. If it does not work,
refer to an authorized dealer.
? Salt water in safety lanyard
cap.
? Clean safety lanyard cap with
fresh water to remove salt
water.
? Improper operation of
MPEM or defective wiring
harness.
? Refer to an authorized dealer.
4 short (while pressing
start/stop button with safety
lanyard already installed).
? Shifter is NOT in neutral. ? Place shifter in neutral. While
moving the shifter, 1 short
beep indicates you reached
the neutral position.
1 short (while moving shifter
to neutral).
? Confirmation that shifter is
now in neutral.
? Engine is now ready to be
started
8 short. ? Defective MPEM (memory). ? Refer to an authorized dealer.
Continuous. ? Engine overheating. ? Refer to Engine Overheats
below.
