Re: Sea Doo injection oil vs. TC-3 oil?
You would be just fine using TC-3 oil on most Sea Doo's. My Sea Doo is a 1990 model with the 587 (yellow) engine, and the head is completely clean using WalMart's generic outboard motor oil.
If you have a SeaDoo XP (or other models with the white engine and RAVE valve), a special full synthetic oil is required. You're just about limited to SeaDoo factory XP oil. Amsoil also makes a synthetic oil that will work in an XP that's slightly less expensive. Those engines are like motorcross cycle motors--running a single ring to minimize friction and use a power valve to change the timing at a specific rpm.
