Welcome Guest - Sign Up today
No announcement yet.
1999 Sea Doo Bombardier Stuck Choke Issue-(common)
  • 1999 Sea Doo Bombardier Stuck Choke Issue-(common)
    Hey all I noticed this to be a common problem with Seadoo GT_ models and I thought I'd share it. On the ones I've experience, they will fire right up, but as soon as you go to gun it...it bogs down and sometimes dies. This happen to you?
    Try this next time:
    After you are warmed up, grab the choke handle and pull it out and then back it while running. Then immediately try to take off. Did it work? No? This time pull the choke and leave it out long enough the the craft almost dies then push it back in. Wait just long enough for it to recover and go.
    This has worked on several machines that I have come across, hope it works for you. If it does, the choke is sticking and you need to repair it.
