Welcome Guest - Sign Up today
No announcement yet.
94 Sea Rayder Mercury 90 run bad?
  • 94 Sea Rayder Mercury 90 run bad?
    Just had stator replaced, now I can't get it to run over 10mph. Dealer says it needs a wear ring. It ran fine before stator failure. I seems to bogg at full throtle. I've changed plugs 4 times, using recommended Quicksliver TCW3 oil and 87 octane gas. It ran out of gas or close to it when this whole mess started. I think it seems as if the dealer doesn't have it timed right. Lots of smoke also which comes and goes and plugs are wet when checked. This is my 1st boat and am wondering why I did this! ha
    Re: 94 Sea Rayder Mercury 90 run bad?
    Hi, Stingray.Welcome to iboats. You don't have a Mercruiser I/O. You have a Mercury Outboard Trouble.Moving this to the correct Forum.Good luck.
    sigpic
    • #3
      Can anyone help me ?I have a 94 sport jet that is dumping gas out of the carbs while it is running.Could this be the reeds hung open.
      • #4
        Mightymite, you are hijacking a thread in the wrong forum. Post a NEW thread in the outboard forum.
        When will people learn that impellers require regular
        replacement and are not drive it till it pukes items?
        1984 Regal Medallion 195
        3.8 V-6 with the dreaded
        OMC Stringer Drive.
        2003 Avalanche w/Hypertech
        If it ain't fixable - don't break it!
