I have a 95 Yamaha WVT700T that does not have a flush kit. I located the port at the rear of the cylinder head where a fitting could be placed to connect a hose to a flush kit. This would be ideal if I could find the fitting that will screw into the head. I measured the screw that normally seals that port and it is only 7.55 mm and the opening is less than that (less than 1/8"). I also have taken the screw to match up the threads and I believe they are not standard. The adaptor would have to have the correct threads on one side and a 3/8" barb on the other. I was thinking about making an inline flush kit using the inlet 3/8" hose but then I need to use a check valve or a on/off valve to avoid the water going out the back of the ski.
Any help would be appreciated.
Thanks
Thanks
