1997 tigershark 770 no spark on one cylinder
pilotame
tried another spark plug and checked connections on coil and area. what is the most probable cause a coil or cdi? how do I check the coil and the cdi. the coil has two spark plug leads coming out of it. do both cylinders spark at the same time.
JUSTINTIME
Re: 1997 tigershark 770 no spark on one cylinder
cut back the spark plug wire a little and try it
do compression check
pilotame
Thanks I was going to try new ignition leads and compression is good.
