So we just bought a Kawasaki 650 SX and it is bogging down bad. So what we did is we took the gas line off and ran it tell it ran out of gas. Then we hooked it back up and primed it and ran. It went great for about 20 secounds then bogged down again. We now know it is getting to much gas and when it builds up it bogs down. So we Cleaned the carbarator completly and the air filter was Horribly Clogged. So we also took the reeds off and cleaned them too. We have not gotten out to test it yet but we think it might have been that there was to much suction from the air filter being clogged causing the primer to leak gas into the carb. So we are going to try this out. We also replaced the spark plugs. So took the carb apart, cleaned air filter, New Plugs, and when we get it on the lake if it bogs down again we are going to take the primer off. Any other suggestions of what could be happening. If it is getting to much gas how do we stop it from getting so much? We also found out it has a slight exhaust leak which i read can cause it to choke out the motor causing it to run lean is this True?
Jimmyboot
Jimmyboot
