Welcome Guest - Sign Up today
  • Dear Community Members,
    Updated 9/29/20 - Upgrades have been pushed until 10/7/20
    Over the last two years, there have been updates to the environment that have introduced challenges in usability, performance, and security. Efforts to improve the technology, user interface and site performance have revealed weaknesses in the platform and outdated software our site uses. This has made it increasingly difficult and frustrating to support and upgrade to more modern reliable standards that users deserve. This is not the experience we want for the members of this community.
    Members want a fast site that performs well across all devices, to be able to find relevant and interesting content, and easily share through text, images, video, and messaging on a secure platform. Our goal is to provide this user experience to all members. We will be updating to a new platform to better meet the needs of this community and allow us to provide support more efficiently. Our focus is to create a sustainable platform that performs well and loads faster on all devices while offering seamless ways to search and connect. Technology is constantly innovating - by creating an environment that we control we can maintain the site with more frequent improvements and maintenance updates.
    Although change can be difficult, we are here to support you through the process. We make every effort to review existing settings and make the changes needed so the migration goes smoothly. If you notice something doesn’t seem correct once the site goes live, don’t panic! We’ll have a dedicated person monitoring as the site goes live to answer any questions and provide support through this change.
    What’s next?
    When will this be happening? The plan is to put our current forums into maintenance mode (off line) at around 9am MST on 10/7/2020! The whole transition should take 30-36 hours. We recognize the user experience is slow and there are bugs from the outdated software. The sooner we can change that the better we can make the experience for you. You’ll start to see activity related to cleanup in preparation for migration very shortly. We will post an announcement to the community prior to starting the actual data migration.
    We appreciate each member’s contribution to this community and look forward to an improved experience for you all.
    - Management
No announcement yet.
1996 GTS Sea-doo
  • 1996 GTS Sea-doo
    Run great 15 min then no power, only creeps along. Replaced thermostat, gas lines and cleaned the carb. Now when you give it Throttle, starts to take off then, then no power only creeps along.
    Had the same model, been there done that. That's a 24 year old machine with a 10 year life span. Check the compression. The engine could be worn out.
    2019 SeaRay SPX 190 OB & Mercury 150 4-Stroke & Merc 5.0 Kicker
    2017 Boston Whaler 150 Montauk & Mercury 60 ELPT Command Thrust & Merc 3.5 Kicker
    2015 Yamaha FX Cruiser HO
    1964 Sea Nymph 14R & 1970 Evinrude Sportwin 9.5
    1960 Mulray 100 Dinghy, equipped with Beaver Oars
    1952 Lyman 15' Mid Steer & Evinrude Big Twin 25
    69 Outboards: 1919-2019, representing 11 manufacturers
    Member ACBS, LBOA, AOMCI
    • #3
      Clean internal carb filters, replace voltage regulator. Your ski may be 24 years old, but it can be repaired indefinitely. And yes, you should run a compression check too. If the above items are checked to be good, then I would look at the clearance between the rotary valve and cover. It might have some wear and need to have a little machined off the lip to bring it back into spec.
      The Fleet:
      2 x 1996 Sea-Doo XPs
      1999 Sea-Doo XPL
      1992 Sunbird Corsair SL 5.0L HO OMC --->The project......transom, floor, hole.....yea it's bad.
      There is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.
      -Kenneth Grahame
