w3Monkey
- Aug 26, 2018
- 4
I have a 1994 Searay Sport Jet with the Mercury Force 90 hp 3 cylinder outboard motor
I had this thing running great then had the air/fuel a little fat 2 turns instead of 1 1/2 and ran it hard with four people in the boat (700lbs)
then it died after half and hour and wouldnt restart.
I pulled the plugs and it spun but water started shooting out of the #3 cylinder. (compression: 120, 128, 105 respectively)
after I spun the motor to cough out the water I put the plugs back in and the motor wont spin. (i can hand spin the motor but a brand new battery new relay and new cables arent enough to spin the motor freely. it will spin freely without the pugs in)
heres my questions: is my first step pull the head i should check the head for crack or to see if i blew the head gasket? or should i not bother because the something in the block is jacked?
