Hi All. Hoping I can get some help with my Sea Doo. Was running great and suddenly died while my daughter was riding it. She said it just suddenly stopped like the lanyard had come out. Couldn’t get it started again.
I’ve been running premium fuel with sea foam added.
It turns over fine, has spark (plugs are new)and will start if I spray gas in the cylinder.
I figured a fuel delivery problem. I have taken the carbs apart and cleaned, bought a carb kit and rebuilt fuel pump, replaced fuel lines, checked filters, emptied and cleaned fuel tank, by-passed fuel selector switch and straight to carb from tank and am pretty confident no leaks in fuel lines.
I have not done a compression test. Was told by previous owner that it was 120 and 130. If this is the case would that be acceptable.
Any thoughts or ideas on what to check or try?
