I just picked up a brand new Smoker Craft Phantom 202 (not the offshore version) with a new Yamaha F115. The boat is 20' 2" with 93" beam, 17 deg dead rise, all welded hull and weighs 1650 lbs empty. The motor is mounted so the ventilation plate is about 1/2" above the V at the keel. I can drop it one hole or raise it up if needed.
Phantom 202 | American Angler by Smoker Craft
It came with a 13x19 prop which didnt perform at all well. Peak RPMs were in the 5500-5800 range with top speed in the 33-35 mph range. the slip calculated out to around 27%.
The dealer let us try a 13.25x17 prop and the results were much better.
RPMs dropped a bit to 5500-5600 and GPS speed went up to 36-37mph for a slip in the 12%-13% range.
Thats a big improvement, but Im still thinking there is room to do better. Im tempted to call this close enough except for three things.
1) The boat was only partially loaded - 1/2 tank of gas and no fishing gear, no kicker or spare battery, no downriggers etc. Our typical trip out will have an easy 300-400+ extra pounds in the boat.
2) The prop seems to be ventilating too easily when turning at speed when trimmed up. It does it at cruise speed (4000rpm/26mph) and full throttle.
3) The bow is riding too low on plane and at full speed. Its almost plowing even when trimmed up as far as it will go without ventilating. This model of boat has the windshield well forward and the splash line is about even with the windshield. Videos of this boat running show the splash line well back from where it is for us.
Based on what Ive read here Im thinking I need to do a few things:
1) Drop the pitch to get the peak RPMs up closer to 6000. Im guessing a 15 or 16 pitch?
2) Lower the motor one hole to help with the turning issue?
3) go to a larger diameter prop to help raise the bow up?
Before doing anything I will finish outfitting the boat so its at its full weight with all the gear mounted in its place and then re-test with this prop.
Im not concerned about top speed or hole shot but I am concerned about engine rpms and how it rides. Im pretty sure if I can get more hull up out of the water it will be better.
Any suggestions, comments, advice would be greatly appreciated!!
thanks
thanks
