Autowizzard
- Jul 29, 2006
- 29
I have searched and not found a definate answer so I'll try here. I have a 1992 four winns Horizon with a 302omc I/O Stock prop is a 14.25x21. I have insalled a new motor with Id safely say 75 more hp. I know stock Max rpm is 46-4800. WIth the stock prop I can not get any higher top speed then before (50) but my rpms are 52-5400. I would figure spinning higher rpms would gain more speed? Acceleration is much better. I also have a 4 blade prop which keeps rpms down to 5000 ish but still 50mph. Yes speed is done VIA gps. My question is when adding power am I correct to go next size up for speed? I already have great acceleration and power but Like to go fast on occasion and not overrev my lower unit or motor. And Yes I keep rpms low 90% of the time as I know OMC stuff is hard to replace.
