So, I just wiped out my lower unit when I hit a rock in Canada fishing. The insurance is sending me a check and I think I will perform the repairs myself and treat myself to a upgraded prop. So here is the question: Boat is a 2008 Lowe 165 FM deep vee with a 2008 50 hp Merc two stroke. I run the boat a lot at high elevation lakes, so performance is keyed towards high elevation. My last prop was a Solas alumuninum 10 pitch 12 inch diameter and the boat performed well with this prop. When running in Canada at about 1200 ft above sea level the motor would pull about 5200 rpms with a normal load and would top out at about 27 mph. When I fish my favorite local lakes, elevation is 7000 ft and motor will pull about 5000 rpms. So, can I benefit from a stainless steel prop, three blade or four, same pitch or a little higher. I have run a 11 pitch solas aluminum before and it did pretty well, but would only pull about 4800 rpms at my favorite lake. I do a lot of trolling with this boat while fishing also.
