Just looking for some affirmation that I'm thinking along the right lines. 2012 23' Sun Catcher pontoon, 3 logs, Yamaha F150. Current prop 3 blade 13.25" - 18" SS. New to the boating thing when I bought and prop came dealer recommend. I think I have a bass boat type prop. I want to go 4 blade alum. (run a rocky lake system). 5700 rpm gets about 37 mph with 2 people 3/4 tank of gas. looking for more mid range performance, cruising 3-4000 rpm and about 20 mph. Not so concerned about top end. I have 1 3/8" room currently between tip of prop and the housing (cavitation plate?). I am looking at 14 - 17 or 14.5 - 17 Hustler 4 blade. Increase in diameter and 1" less pitch from what I read and understand should be a slight decrease in WOT and speed, but better low and mid range. Am I on the right track? Open to suggestions. How close can I get to the housing if I go even bigger in diameter? thanks in advance.
