When I bought the boat it had engine issues so I could not figure out anything regarding the prop last season. Now that I have fixed the leaky intake valve and changed the exhaust from one-piece manifolds to brand new two-piece, I'm ready to examine the prop.I also put in new spark plugs and set the timing to factory spec. The former owner told me it would do 43mph when the engine was working right.
This is a 1996 Rinker Flotilla, 24' deck boat. I believe it weighs 3,450, empty, and has a 43G fuel tank. It has a 4.3LX engine, that is 180hp, from what I understand. Engine SN: 0F821477
My current prop is a Quicksilver 48 16316 A5 19P, stainless. (14.5" x 19P) I put this prop on because the original that came on the boat had a few nicks in it where this one had none, and it was a leftover from my last boat. The original prop that was on it when I bought it was a Michigan Match, PN: 033004, 14" x 19P.
My load yesterday was about 450 lbs plus a full tank of gas. Best I could get out of it, with the trim just below blow out was 32.3 mph, per GPS, at 3920RPM. I'm looking for top speed and fuel mileage, as I hope to take some long river trips (70-100 miles one way). I may pull a float here and there, but doubt I will ever be trying to get a skier out of the water quickly.
I'm thinking I need to be in the range of 4400-4800, for RPM at WOT, which suggests that I may need a 17P or 16P. The Mercruiser prop selector was suggesting 17P 3 blade or 18P 4 blade, when I put in my boat info, including weight. I do not absolutely know what the red line for this engine is, I am only guessing from other posts I have read here.
Looking for ideas as to what prop to try next. I am open to 3 or 4 blade but want to stay with stainless if possible.
Thanks,
Chris
Thanks,
Chris
