help identifying mercury prop HHM22004...please
khes142
Hi. 13 inch diameter aluminum mercury prop mounted on an 85hp merc outboard. It has HHM2200 4 stamped on the hub.I can not seem to find its pitch info anywhere. Any ideas of where reference charts are located?? thanks in advance.
walleyehed
Re: help identifying mercury prop HHM22004...please
It will be stamped on the nut-end of the hub or possibly the front. If not there, it should be stamped between the blades.
