If you don't have the thrust washer, the prop will bore itself into the gearcase.
Yours might need a somewhat unusual one. Most are tapered, but I'll bet your porpshaft has a shoulder instead of a taper. The part number is 313925 for the thrust washer and 314504 for the spacer under the nut. You'll have to get those through a Johnson/Evinrude dealer.
