I have a 1974 Rally 17' made by Mirrocraft that I recently repowered with a 1995 Mercruiser 3.0 4cyl making 120 HP due to using an old manifold and carb from a 120. I have a pretty banged up three blade 17P 15 3/4 diameter prop on it now and make around 34MPH at 4300 RPM WOT with two on board and 18 gals of gas. I would like to replace the prop as it is pretty beat up, but don't need a really fancy prop. Mostly will be used for running around with some waterports towing (skiing, wakeboarding, tubing). Top speed is not a major concern at all since the boat is so short, I can hardly ever go that fast!!<br />My question is, is there any benefit or drawback to going down in diameter and increasing the pitch? Right now it is about as big as it can be without hitting the gearcase. If I went to a 14" for instance, how much does that decrease in diameter usually need to be compensated for with increased pitch? For instance, one inch diameter difference equals one inch pitch??? Any recomendations on a prop for me? It is going on a pre Alpha leg with 1.98 ratio. I used the Mercury prop selector and it came up with a 13 1/2" diameter 23 pitch Vengeance or a 14"dia 23 pitch Black Max? 23" pitch??? That seems pretty agressive to me for this weak of a boat? <br /><br />Thanks
