Re: 3 HP prop for johnson diassembly?
That's good news, I think the 5.5 will be a lot better on your boat in light of your last post. I wasn't sure the motor was on a 5m craft and you were pushing against displacement speed.<br />Everything should be transferrable from your elk towing prop. Just remove the rubber cone, cotter pin, prop nut and thrust washer, and pull the prop off. If the clutch and ring stay stuck in the propeller, just reach in and pull them out. There's nothing really holding them in there. Then just set them into the 5.5". If they're stuck, try a little light oil to lubricate the clutch ring.<br /><br />The whole works is held in place by the drive pin and the prop nut, so don't forget to get a new cotter pin for the prop nut.
