20’ Pontoon pitch
Stubrown12
Recently purchased a 20’ pontoon with a 40 hp. Switched to a 75hp Mercury. The pontoon will run 18/19 mph on a 19 pitch three blade prop only turning 4000rpms. What pitch do I need and 3/4 blades. Thanks in advance.
WesNewell
A rough guess would be a 12p 4 blade. Try the mercury prop finder.
ahicks
2 stroke or 4 stroke engine?
3 blade if speed is your objective, 4 blade if max thrust is the better plan.
19p obviously way to big.
Our Honda 90 on our lightly loaded 24' toon likes a 15p 3 blade (5500/26mph), or for neck jerking hole shot (pulling), a 13p works good (6100/24mph).
A similar 75 on a lightly loaded 'toon should work good with one of those props, or maybe with an inch less pitch. Noteworthy maybe, is that the 4 strokes sound kinda busy when run at max rpm (6000). Sound MUCH better and are sometimes faster when set up at 5500.
ahicks
You may be OK with smaller kids on skis, but I would plan on lots of tubing.
I'd be tempted to try an inexpensive (Solas) 13-14p alum. 4 blade with the idea it should be close. You may end up having to buy a second prop to nail it.
