Welcome Guest - Sign Up today
No announcement yet.
20’ Pontoon pitch
  • 20’ Pontoon pitch
    Recently purchased a 20’ pontoon with a 40 hp. Switched to a 75hp Mercury. The pontoon will run 18/19 mph on a 19 pitch three blade prop only turning 4000rpms. What pitch do I need and 3/4 blades. Thanks in advance.
    3 or 4 cylinder 75HP?
    When in doubt,Trim it out!!!
    Business Owner & Certifed Technician
    Boats I own & use
    20ft Javlin w/250 Junkrude
    17ft Bullet w/200 Merc (SOLD!!)
    13ft Allison w/150 I-6
    17ft Hydra-Sport 175GT
    15ft Allison w/75 Stinger(project)
    14 x 48 Drifter with 1100SS Merc
    • #3
      A rough guess would be a 12p 4 blade. Try the mercury prop finder.
      • #4
        2 stroke or 4 stroke engine?
        3 blade if speed is your objective, 4 blade if max thrust is the better plan.
        19p obviously way to big.
        Our Honda 90 on our lightly loaded 24' toon likes a 15p 3 blade (5500/26mph), or for neck jerking hole shot (pulling), a 13p works good (6100/24mph).
        A similar 75 on a lightly loaded 'toon should work good with one of those props, or maybe with an inch less pitch. Noteworthy maybe, is that the 4 strokes sound kinda busy when run at max rpm (6000). Sound MUCH better and are sometimes faster when set up at 5500.
        • #5
          3 cylinder/2stroke
          • #6
            Wanting to pull the kids. Maybe try skiing
            • #7
              You may be OK with smaller kids on skis, but I would plan on lots of tubing.
              I'd be tempted to try an inexpensive (Solas) 13-14p alum. 4 blade with the idea it should be close. You may end up having to buy a second prop to nail it.
              • #8
                ive got a 20 ft toon with a 115 4 stroke on it. got a 15p 3 blade on it
                "Na ise kalyteros anthropos apo ton patera sou"
                (greek= Be a better man than your father)....
