Welcome Guest - Sign Up today
No announcement yet.
Need prop ID help
  • Need prop ID help
    I have a stack of older props of various sizes. Have some that I can not find which motor these fit. Example OMC 382702. Is there a reference to pair up these odd props with the proper motor/outdrive? Thanks and be safe on the water.
    Is that Number correct? I can't find it on any OMC part Database
    • #3
      My bad OMC 382762
      • #4
        14 X 13 A low Pitch prop for
        71 - 74 50hp
        Most, but not all 3 cylinders
        1969 and newer Crossflow V4s
        some Looper, V4s
        • #5
          Thank you will need your expertise later.
          • #6
            I have 2 aluminum Michigan 4 blade props 10 inches in diameter. Stamped P12 and AMC 445. Any help would be appreciated. Be safe and God Bless America..
            • #7
              I have 2 Michigan four blade aluminum props. 10 inch diameter .Stamped AMC 445 P12. Any help identifying these would be greatly appreciated. Be healthy and God Bless the USA.
