Hello,
I'm replacing the prop on my 2004 194 funship.
I'm running a newer Volvo penta 5.7l / sx outdrive. Upgraded from the 5.0gl by previous owner.
I'm not very familiar with props other than I've been running a 3 blade aluminum. Not really sure on the specifics of pitch and diameter other than it's whit'my last mechanic told me to get. So I'm guessing OEM.
I'm thinking about swapping with a 4 blade stainless steel prop but have no clue what specs to get.
Been thinking something's been off with this current set up as I've never been able to break 40mph full throttle and it takes forever to plane with more than 3 ppl onboard.
I usually cruise at around 3500rpms at about 20-25mph
and at about 30-35mph at 4500-5000rpms.
I'm thinking a good bit of this has to do with a wrong prop for what im running.
pulling the boat out to swap the prop in the next week and fix an oil leak in the outdrive I noticed on my last outing. Hopefully a simple fix. (Stupid logs)
Any help or input you guys could give me in this matter would be greatly appreciated!
