Welcome Guest - Sign Up today
No announcement yet.
Thrust washer question
  • Thrust washer question
    I just put a new solas prop on my Volvo penta sx outdrive & after running it I checked everything & the prop is rubbing the drive unit. Is there a proper thrust washer I should be using? The previous prop was a turning point.
    The Standard Thrust Washer, may or may not work with props other than VP or OMC. When I put the Enertia on my VP, the proper Thrust Washer came in the Mercury Hub Kit for VP. Whether a Washer for a TP prop will work on a Solas... ????Check with Solas as to what you need. Gear case Housings are not very cheap
    • #3
      Agree with Jimmbo to be fair. Not wanting to sound bad or prop snobby...but it’s likely your boat deserves a better prop than that. I can’t tell you how much of a difference a real good prop can make to a boat. It’s the single biggest improvement you can make to your boat. Sorry to preach...but get a good one. You’ll be amazed.
      • #4
        A lot of people do not want to spend a lot, and there are 3rd party props marketed as a Price Point(<$100 Can). Myself, I don't flinch when I buy a Prop that lists for >$1000(Can). I swear at some of the brands/models that some members hold in High Regard, but they are entitled to their Opinion. I will admit I do have access to test any of the Props in my Dealer's inventory, so I have some insight as to which Brands are less than terrific, and which are superior regarding Quality as well as Performance.
