Welcome Guest - Sign Up today
Private Messages
We are aware of a current issue where your messages screen does not properly load and we are working on a fix.
In the interim, you can access you messages by navigating to this link: https://forums.iboats.com/privatemessage/notification
Apologies for the inconvenience.
See more
See less
Prop and overall ratio help needed
  • Prop and overall ratio help needed
    Hello all ,
    I could use some help with a project that I am working on . I am converting or upgrading my drive. I am going from an old electric shift OMC stringer to a mechanical stringer. I have aquired all of the parts but now I need to get some props for the new unit and could use some help there.
    My "old" electric shift drive ratios.
    upper - 21/19
    lower - 15/23
    I dont know the overall ratio or how to calculate. I can tell you that I use a 14x14 for 'mountain lakes" and a 14x16 for lower elevations about 3700' or so and those 2 props have always worked great and put the RPMs in an acceptable range
    My "new" drive ratios
    upper 21/16
    lower 14/26
    overall .71 (from my manual)
    So my main question is - How can I calculate or find out what prop(s) will be best for new drive ? basically an equivalent of what the previous props and drive ratio
    any help would be appreciated so I can start buying props for the new setup .
    Thank you much
    1977 Bellboy 18 footer with a 175 HP OMC 302
    "The trouble with quotes on the internet is that it's difficult to determine whether or not they are genuine." - Abraham Lincoln
    Make sure the lower is a 800 series not 400
    When in doubt,Trim it out!!!
    Business Owner & Certifed Technician
    Boats I own & use
    20ft Javlin w/250 Junkrude
    17ft Bullet w/200 Merc (SOLD!!)
    13ft Allison w/150 I-6
    17ft Hydra-Sport 175GT
    15ft Allison w/75 Stinger(project)
    14 x 48 Drifter with 1100SS Merc
    • #3
      I have the complete out drive and it's an 800 with the 21/16 ratio in upper
      • #4
        Well your engines WOT range is 3800 - 4200 rpm
        Your old drive, if stock, was listed a 1.79 ratio for a pre 78 175hp, your new unit is in the range of 1.4:1 which is quite a jump
        What rpms were you attaining with the old unit and prop?
        • #5
          Shoot , that's a pretty big difference. Thanks for figuring that out
          With my 14 pitch I can hit 4000 and that puts the boat at about 35
          • #6
            So knowing the large gap in overall ratio , I may have to change strategy . That may run like a dog.
            That stinks , cuz that 5.7 upper is in great shape and resealed . Oh well , I can just sell it .
            Now the question lies if I can use my electric shift upper with the mechanical lower. It looks identical and the vertical driveshaft is listed as the same part , so thats promising . Will have to pull it and take a better look .
            • #7
              A pre 78 upper housing has a different part#(0980804) than the post 77 upper housing(0982226).
              The upper driveshafts are different too.
              That doesn't mean they won't swap, but...
              • #8
                Actually jimmbo , they appear to all be the same from my initial reaserch . The vertical driveshaft is the same for all low profile uppers 909120 , water pump shaft too , so that means splines areaall the same. You may have just picked a tall profile model.
                Also I found this on a site that rebuilds stringers
                "The ratio change is in the upper housing. All 1973 - 1985 upper housings are identical* except for the tooth count on the gears and left or right steering worm."
                ​​​​​​I will pull off my electric shift and verify and measure but at this point it looks somewhat promising .
                I need a favor , can you tell me what my overall ratio will be assuming I can get this to work ? The ratios in the lower are different and that will change my overall ratio if I use the same upper
                So it will be upper of 21/19 and lower of 14/26
                That shouldn't be a huge difference on overall ratio to overcome with a prop change in pitch an inch or two from my current setup
                Thanks again for the help
                • #9
                  I thought the housing where different lengths....
                  Boats I own & use
                  • #10
                    you are right , there were different lengths . The Tall vs short profile . The tall profiles though I think were only in the late 60s early 70s . Both of my units are the short profile .
                    • #11
                      Actually , I did some digging and was able to figure out the calculation for compound gears .
                      My old electric shift was a total Ratio of 1.38 (21/19 upper +15/23 lower)
                      My "new" mechanical shift has a total ratio of 1.41 (21/16 upper + 14/26 lower)
                      So that is only a difference of .03 , that should be fine right ? The prop is basically spinning at the exact same RPM on old vs. new drive .
                      • #12
                        Should work ratio wise.....
                        Boats I own & use
                        • #13
                          So one last question on this . My electric shift used 14 inch diameter props , the 800s appear to use 15 inch diameter props .
                          Based on these ratios , and the change in diameter , should I stick with 14 pitch for higher elevations and 16 pitch for lower elevations ( that was basically the strategy before )
                          Will a 1 inch larger diameter prop change that ?
