I have the propeller system in the attachment. The application is a mercury 120hp, 13 x 17 RH, 3 blade propeller. I am looking to replace the current propeller, but I am not able to identify the interchangeable hub system (there are no part numbers stamped, etc.). Can someone help?
No announcement yet.
can someone identify interchangeable hub propeller system
Thanks, everyone so far, for the replies. I am kind of fond of this hub system, and I purchased it, originally, for the purpose of having an interchangeable prop, and, now, that I am due for a propeller replacement, that does not sound great that the hub may be obsolete! The shaft adapter is for a 15 spline (mercury) outboard (gear case), not the I/O. The propeller finish, of the unit at hand, was also unusual - not the typical black paint, but a light grey color and more durable coating that did not peel easily...
If it didn't take off, obsolete, is obsolete,....... I've never seen one,....
Merc propshafts are all the same, 'tween the large outboards, 'n I/Os,.....
Looks like an old Turning Point or could be Combo prop which from what i understand is now turning point. I got one in my garage i can post a picture of once i get home. You'll have to get a new hub and prop. I just had to do the same on my boat.Last edited by Bikestdy; December 6th, 2018, 11:52 AM.1985 4Winns Horizon 170 w/Merc 470
It is a Turning Point hub and appears that is was only available from 99 to 04 (some where between 11 and 14-19 years ago, that is not that short of a time before it went obsolete). You can watch Turning Points timeline video to see a picture of that hub at the 49sec mark. Here is the link to the video, https://www.youtube.com/watch?v=yj-d-SlM-ew . Here are the pictures of what I have. I think that I left my 2nd Combo Prop hub and spare prop in my boat which is in storage, I can get a pic in a few weeks if someone would want to see it. The hub on the right in the pictures is the first hub system and the one on the left is what you have. Both props pictured are for the hub on the left. And the second picture is your second way of identifying, if it has the vent holes it is a Turning Point as that is something that only they have done on their aluminum props. So as we said your going to need a new prop and hub.Last edited by Bikestdy; December 7th, 2018, 05:59 AM.1985 4Winns Horizon 170 w/Merc 470
If there is some good news, it is that the manufacturers have all switched to a common design (though each has a variation to the execution of the hub ex: one piece/hub molded to insert, rubber hub with brass insert, composite hub with molded in brass). They all can be used on the competitors props, Mercury, Solas, Michigan Wheel, and Turning Point all share the same design and can all be used on each others props. So you can now switch prop brands and use what ever brand hub (of the new design) that you already have keeping you from being locked into a particular prop brand.
And as Texasmark said in this post, https://forums.iboats.com/forum/gene...ade-to-4-blade
"The problem I personally have with the hub is that it's made of plastic and brass/bronze. The rubber hub slips and reseats itself when striking an object. On the plastic/metal hub, there is nothing to give as the outer diameter is locked to the prop and the inner locked to the prop shaft.......walla, plastic all over everything.......dead in the water........just like back in the days of the shear pin. No thanks!!!!!!!"
As he states Turning Point uses a composite hub.
For this reason I bought a Solas Rubber hub (and I figure a rubber hub will help dampen a hit over a composite hub) with my Turning Point prop and it fits fine.Last edited by Bikestdy; December 11th, 2018, 09:07 PM.1985 4Winns Horizon 170 w/Merc 470
iboats Boating Forum Directory
Over 100,000 Questions & Answers
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Activities and Destinations
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats (250+ Manufacturers)
Bayliner Boats
Sea Ray Boats
Zodiac Boats
