We bought a Sylvan Mirage 818 pontoon boat last year. We bought the largest engine we could get, a Yamaha T60. The prop that came with it is a 13 1/2 X 9 Talon SDS Aluminum prop. My question: Is this the prop that comes standard on these engines? If so, how would one determine if there is a better prop option for a pontoon boat vs a more traditional hulled boat. I've read the sticky on props and I'm going to try to include as much information as I can following the template that was suggested.
1) Performance Issue you are trying to correct: Trying to get a little more speed given our HP limitations.
2) Current Prop: Yamaha, 6EK-45941-00-00, Aluminum.
3) Diameter and Pitch: 13 1/2 X 9
4) WOT: 6000 RPM, 21 MPH with four adults and 21 gallons of fuel.
5) Engine Make and Model: 2017 Yamaha T60
6) Boat: 2017 Sylvan Mirage 188 (19'), two tubes, Approximately 1690 lbs dry weight (boat and motor)
We have approximately 40 hours on the engine. We've noticed a decrease in speed according to our speedometer of 4 to 5 MPHs. The engine just had it's first factory authorized service. I inspected the prop and can't find any damage that I feel would cause any problems. Would a SS prop be a better choice for what we would like to achieve? Your comments and suggestions would be greatly appreciated.
