Problem - when making very tight turns at moderate speeds (turning around to pick up a skier), my 115 Yamaha outboard would have a continuous beep and would throttle down. Most times I could go to neutral but sometimes I would have to cut the motor to get it to stop. Recently, I chewed up the prop a little on some oysters and the problem is much worse. When throttling up for too long, navigating rough water or turning tight, I feel the prop vibrate a little and the engine gives me the warning sound.
I've read this is an overheating warning, but it only happens when the prop is being flexed during a turn and I feel vibration. Hoping a new prop will fix.
Carolina Skiff DLV 218 (2013)
Yamaha 115 with aluminum 3 blade prop
13 1/4 X 15-K prop size
WOT - about 6300 at 37 MPH
