eMKay
- May 14, 2008
- 54
I have a 1982 Starcraft SS 160 with a 1985 Johnson 60 (2 cyl, small gearcase), The current prop is 12.25 x 15p and I get 4500rpm max at 35mph with just me and 30 loaded with. It gets up on plane fine, pulls a tube fine, just not getting max RPM. I was thinking of changing to a 13p prop but was wondering if that would be detrimental since the boat performs just fine everywhere else. I cruise at 20-22 mph at 3500rpm, does changing to a 2” smaller pitch move RPM up 4-600rpm across the entire rev range, or is it only at WOT and is a scale depending on RPM? (Example, my 3500 cruise RPM is now 3700 and not over 4000?)
