aviationMx
- Jul 30, 2018
- 19
Boat: 2001 ssi 216, 5.0 l gm efi rated at 240 HP.
Props: :Replaced a 3 bladed 14.25 inch 21 P prop with a alpha 4 14 inch 20 P.
At full throttle with one person and 30 G of fuel, I can barely reach 4200 rpm- I think the range is 4200 to 4800 for WOT.
At first I wasn't too worried because I needed a tune up but I have now completed installing all new ignition parts and new TBI injector seals and checked the butterfly position is fully open at full throttle. Motor starts easily and seems to be running to spec (although perhaps small for a 22ft open bow). ..The 3 bladed prop put the RPM around 4700 and both props or not SS.
the Alpha 4 planes out fast and pulls tubes easily at lower speeds, not to mention better handling at low speeds but I'm concerned that I'm putting stress on the 305 motor w/ 375 hours. Do I need to reprop or is this acceptable ?
Been reading this forum for years, first time posting,
Chris
SML VA
Chris
SML VA
