what prop will I use on 1982 sea ray amberjack 350 merc 26 horse 10 foot beam
S Seadogpdd Recruit Joined Jul 27, 2018 Messages 5 Jul 27, 2018 #1 what prop will I use on 1982 sea ray amberjack 350 merc 26 horse 10 foot beam
Scott Danforth Grumpy Vintage Moderator still playing with boats Staff member Joined Jul 23, 2011 Messages 47,499 Jul 27, 2018 #2 welcome aboard I assume you mean 260hp. what drive is on there? what is your current prop? if you have none, you may need to borrow a test prop or two. my first guess would be a 19P or a 17P as with a 10' beam, thats a big boat.
BWR1953 Vice Admiral Joined Jan 23, 2009 Messages 5,847 Jul 27, 2018 #3 Seadogpdd said: what prop will I use on 1982 sea ray amberjack 350 merc 26 horse 10 foot beam Click to expand... Are you asking what was the original prop on that boat?
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 70,513 Jul 29, 2018 #4 Seadogpdd said: what prop will I use on 1982 sea ray amberjack 350 merc 26 horse 10 foot beam Click to expand... Ayuh,..... Welcome Aboard,..... The prop that allows the motor to run in the recommended rpm range, at Wot,......
