Hello all, trying to find a better prop for my boat, 1989 Sunrunner 195 cuddy. The original AQ151 was replaced with a 3.0l 115hp engine, leg is a Volvo sp-a 2.15 ratio. Boat is roughly 2500lbs, with two adults, gear and fuel roughly 3100lbs. Top end is 28mph by gps, at only 4000 rpm via boats tach. Calm lake, 40ft elevation. Prop is a stainless 15x19 3 blade. I know it's over propped, I need to be up near 4600 rpm. I am thinking a smaller prop might actually improve my top speed as well. Should I be reducing pitch or diameter, or possibly both?
