So just going through my new-to-me 2002 19' Hurricane deck boat, and she has a somewhat beat up Merc Vengeance 19". I'm also hitting 5200 rpm with it, so as long as I need a new prop, I might as well find something that fits a little better.
Anyway, any suggestions as far as model/pitch?
So the details:
1) Performance issue you are trying to correct.
Drop the RPM to 4800
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
Merc SS Vengeance 19"
3) Current prop diameter and pitch (required).
14" diameter, 19" pitch
4) Wide open throttle RPM and speed with an average load (very helpful)
5200 RPM, 44 MPH on GPS (15% slip)
5) Engine/drive make, model, year, and HP
Merc 2002 2 barrel 4.3l Vortec on a Alpha 1.81
6) Boat make model, year, length and weight
2002 Hurricane Fundeck, 19', Dry weight is #3055, so max normal load is probably close to 3800#
So the details:
