55Crestliner
- Aug 31, 2004
- 192
I'm running a 1972 50hp Evinrude on a 1956 Crestliner aluminum runabout.
This motor is a recent addition to this boat.
The prop that came on the motor is a 13.25 X 17p that was pretty chipped up on all the blade edges. I shaved down the chips to smooth them out. Reducing the diameter by about 1/4 inch per blade.
This prop was producing 5900 RPM with a light load, and very close to that, 5800 RPM with four people on board. I bought a new prop. It is a 13.25 x 19p with cup. It dropped my RPM by a full 1100 to 4800 light load. It was my understanding that 2 inch of pitch would only drop about 400 RPM.
RPM goal at WOT is 5500.
Am I simply dealing with such a drastic change in prop design between the older reduce diameter prop and the new one? (As in the new one is a much more aggressive design?)
Would it be the logical solution to get a 17p prop of the same brand and design as the 19p that I bought?
